Hello -
Looking to organize my custom sheet set property data fields for my designers...
I currently learning/setting-up my companies project setup process, learning about how convenient sheet-sets can be if set up properly.
Is there a way to add a sub category in the sheet-set custom properties which currently contains the sub categories: Sheet set, Project control, Sheet creation, Sheet set Custom Properties?
Currently all custom properties I have added fall under the SHEET SET CUSTOM PROPERTIES sub category.
Can these sub-category be renamed?
Thank you for your time!
