AutoCAD Forum
AutoCAD 2025 - Sheet Set - Add a sub categories to custom properties
1 REPLY 1
AnthonyP6TSNY
142 Views, 1 Reply
Hello -
Looking to organize my custom sheet set property data fields for my designers...
I currently learning/setting-up my companies project setup process, learning about how convenient sheet-sets can be if set up properly.
Is there a way to add a sub category in the sheet-set custom properties which currently contains the sub categories: Sheet set, Project control, Sheet creation, Sheet set Custom Properties?
Currently all custom properties I have added fall under the SHEET SET CUSTOM PROPERTIES sub category.
Can these sub-category be renamed?
Thank you for your time!
Labels (2)
1 REPLY 1
We use subsets. All of our data is either Sheet Set or Sheet Set Custom Properties in the main Sheet Set. Our subsets hold new sheet templates. You can rename the subsets. I'm not sure if this helps.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Forma Design Contest
AutoCAD Beta
