AutoCAD Forum
Registry key loss
5 REPLIES 5
UNISOL
1386 Views, 5 Replies
Registry key loss
After a recent registry clean the AutoCad regostry key(s) was changed/delete and thge applicaiton is asking for a re-install.
Is there any way to restore the key(s)? with reinstall?
Have a screen shot of the error message ...
5 REPLIES 5
Patchy
in reply to: UNISOL
You can try System Restore before reinstall autocad.
UNISOL
in reply to: Patchy
Looked at system restore and it seems that the restore point is at the MS updates I did yesterday ... if I restore I'll lose the updates but that also suggests that the updates might have caused the change/deletion ...?  The list of applications that would be affected by the retore does not include the registry clean application I used ...
UNISOL
in reply to: UNISOL
Didn't find a suitable solution so I re-installed AutoCAD.  Problem solved.
in reply to: UNISOL
There is your problem....
wispoxy
in reply to: UNISOL
It's faster to just reinstall than recover, depending on your priorities.
Forma Design Contest
AutoCAD Beta
