After a recent registry clean the AutoCad regostry key(s) was changed/delete and thge applicaiton is asking for a re-install.
Is there any way to restore the key(s)? with reinstall?
Have a screen shot of the error message ...
Solved by wispoxy. Go to Solution.
Looked at system restore and it seems that the restore point is at the MS updates I did yesterday ... if I restore I'll lose the updates but that also suggests that the updates might have caused the change/deletion ...? The list of applications that would be affected by the retore does not include the registry clean application I used ...
@UNISOL wrote:Looked at system restore and it seems that the restore point is at the MS updates I did yesterday ... if I restore I'll lose the updates but that also suggests that the updates might have caused the change/deletion ...? The list of applications that would be affected by the retore does not include the registry clean application I used ...
There is your problem....
