AutoCAD Forum
reference details
6 REPLIES 6
437 Views, 6 Replies
reference details
6 REPLIES 6
RobDraw
XREF File - (C)
First Referencing File - (A)
Next Referencing File - (B)
In the referencing drawing (A), it doesn't make any difference. The difference is when that drawing (A) is referenced into another drawing (B). If drawing (C) is set to ATTACH in drawing (A) and (A) is referenced into drawing (B) then (C) will be seen in drawing (B). When (C) is set to OVERLAY in drawing (A), reference drawing (C) will not be seen in drawing (B).
Rob
3wood
My opinion: Attach or Overlay?
RobDraw
in reply to: 3wood
Your wording is not very clear, but I think you've got it backwards.
Rob
in reply to: 3wood
I WANT TO ASK YOU SOMETHING ABOUT YOUR ANSWERS.I read the first answer and i read the second answer ,and i feel that there is a contrast
2.second answer
ice_screenshot_20160505-155450.pngwhen i press the button attach or overlay i read this informationsice_screenshot_20160505-155431.png
A.
i will expain better who is the contrast with my opinion .
  the contrast became with the second answer
If the xref to be shared among other drawings, then the best type for it is OVERLAY.
b.  the contrast became with the second answer
the contrast contrast
if it is only part of the host drawing, not part of other drawings, then the best type for it is ATTACH.
Do i make mistake or not?
RobDraw
You are right. They are contradictory. If you read the help file, you can get AutoDesk's explanation, which will agree with what I said.
Rob
RobDraw
in reply to: 3wood
You should change the wording of your opinion or switch "overlay" and "attach". It is very misleading  especially coming from an expert elite.
Rob
Forma Design Contest
AutoCAD Beta
