Solved by RobDraw. Go to Solution.
Solved by 3wood. Go to Solution.
XREF File - (C)
First Referencing File - (A)
Next Referencing File - (B)
In the referencing drawing (A), it doesn't make any difference. The difference is when that drawing (A) is referenced into another drawing (B). If drawing (C) is set to ATTACH in drawing (A) and (A) is referenced into drawing (B) then (C) will be seen in drawing (B). When (C) is set to OVERLAY in drawing (A), reference drawing (C) will not be seen in drawing (B).
Your wording is not very clear, but I think you've got it backwards.
I WANT TO ASK YOU SOMETHING ABOUT YOUR ANSWERS.I read the first answer and i read the second answer ,and i feel that there is a contrast
1.first answer
2.second answer
when i press the button attach or overlay i read this informations
A.
i will expain better who is the contrast with my opinion .
the contrast became with the second answer
If the xref to be shared among other drawings, then the best type for it is OVERLAY.
b. the contrast became with the second answer
the contrast contrast
if it is only part of the host drawing, not part of other drawings, then the best type for it is ATTACH.
Do i make mistake or not?
You are right. They are contradictory. If you read the help file, you can get AutoDesk's explanation, which will agree with what I said.
@3wood wrote:My opinion: Attach or Overlay?
You should change the wording of your opinion or switch "overlay" and "attach". It is very misleading especially coming from an expert elite.
