AutoCAD Forum
"Square Diameter" Symbol
8 REPLIES 8
Message 1 of 9
PascalJ_87210
15125 Views, 8 Replies
Can someone tell me how to insert a square diameter symbol in Autocad whether in a text or a dimension using ALT?
I cannot find the code anywhere.
For a round diameter, I always use ALT 0216 but I cannot find the code for the square diameter (a strike thru a square instead of a strike thru a circle).
I want to use the symbol for dimensioning either a square HSS or a square plate.
Thank you
8 REPLIES 8
Message 2 of 9
rkmcswain
in reply to: PascalJ_87210
Here are a bunch of results:
https://www.google.com/search?q=autocad+square+foot+symbol+site:forums.autodesk.com
Most say you're going to have to create this symbol in the font of your choice, or find it in a TTF if you want to go the TTF route.
Message 3 of 9
john.vellek
HI @PascalJ_87210,
I have searched through all my TTF fonts and I don't see a character definition like that.  You might be able to find a SHX font that has this character defined.
You might also check the Autodesk App Store to see if any of the structural add-ins include this symbol.
John Vellek
Message 4 of 9
Patchy
You can use this:
Message 5 of 9
PascalJ_87210
in reply to: Patchy
I downloaded the font and inserted that square. It works just fine.
Thank you very much for the help.
Message 6 of 9
john.vellek
Hi @PascalJ_87210,
Make sure that when you are searching for a font such as the Meiryo one suggested by @Patchy, that you look for a TTF font and not Open Type (with Postscript outlines).  Also realize that this font is a commercial font and will have to be purchased.
John Vellek
Message 7 of 9
scot-65
Late reply here...
I was unable to find anything that resembles a "square-foot" symbol (%%159)
other than the ones found in the "archstyle" shx font library.
There are three files, unfortunately I do not remember their true SHX file names...
After extensively searching unicode/HTML, etc. I have not been able to find such symbol.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 9
john.vellek
Hi @PascalJ_87210,
I ran across this article on thesourcecad.com previously and it took me a while to re-locate it for you. It describes the process of adding your own special symbols and characters to a font. I hope this proves useful to you.
John Vellek
Message 9 of 9
MIranmanesh
 this is the closest thing to what you need.
Forma Design Contest
AutoCAD Beta
