Can someone tell me how to insert a square diameter symbol in Autocad whether in a text or a dimension using ALT?
I cannot find the code anywhere.
For a round diameter, I always use ALT 0216 but I cannot find the code for the square diameter (a strike thru a square instead of a strike thru a circle).
I want to use the symbol for dimensioning either a square HSS or a square plate.
Thank you
Solved by john.vellek. Go to Solution.
Solved by Patchy. Go to Solution.
HI @PascalJ_87210,
I have searched through all my TTF fonts and I don't see a character definition like that. You might be able to find a SHX font that has this character defined.
You might also check the Autodesk App Store to see if any of the structural add-ins include this symbol.
I downloaded the font and inserted that square. It works just fine.
Thank you very much for the help.
Hi @PascalJ_87210,
Make sure that when you are searching for a font such as the Meiryo one suggested by @Patchy, that you look for a TTF font and not Open Type (with Postscript outlines). Also realize that this font is a commercial font and will have to be purchased.
Late reply here...
I was unable to find anything that resembles a "square-foot" symbol (%%159)
other than the ones found in the "archstyle" shx font library.
There are three files, unfortunately I do not remember their true SHX file names...
After extensively searching unicode/HTML, etc. I have not been able to find such symbol.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Hi @PascalJ_87210,
I ran across this article on thesourcecad.com previously and it took me a while to re-locate it for you. It describes the process of adding your own special symbols and characters to a font. I hope this proves useful to you.
