AutoCAD Forum
"Drawing Purge" Plugin is not supporting in AutoCAD 2023
3 REPLIES 3
a.siddqui
455 Views, 3 Replies
a.siddqui
Observer
Observer
why drawing Purge Plugin is not supporting in CAD 2023, which is very important for us to reduce a bigger file size in a very small size,
[ The subject line of this post has been edited to include the product name by @handjonathan ]
3 REPLIES 3
vinodkl
in reply to: a.siddqui
vinodkl
Hi @a.siddqui
As per the description of the plugin it does support AutoCAD 2023 version. See screenshot below. If you are having problem with the plugin you can contact the developer of the plugin and its highlighted in the screenshot 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @a.siddqui
RobDraw
RobDraw
There are other ways to accomplish that.
Rob
Rob
pendean
pendean
Community Legend
Community Legend
@a.siddqui Works fine for me in 2023.1.1 if you remembered to download and install it after you installed 2023, instead of the shortcut of a migration from an older version
AutoCAD Inside the Factory
