why drawing Purge Plugin is not supporting in CAD 2023, which is very important for us to reduce a bigger file size in a very small size,
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Hi @a.siddqui
As per the description of the plugin it does support AutoCAD 2023 version. See screenshot below. If you are having problem with the plugin you can contact the developer of the plugin and its highlighted in the screenshot 🙂
@a.siddqui wrote:is very important for us to reduce a bigger file size in a very small size,
There are other ways to accomplish that.
@a.siddqui Works fine for me in 2023.1.1 if you remembered to download and install it after you installed 2023, instead of the shortcut of a migration from an older version
