'QUICK SELECT' tool not working
- Mute
- Permalink
- Report
Hello everyone.
I want to exclude texts from a selection of several objects I have in AutoCAD 2025, but the 'Quick select' tool is not working as I expect. Here is what I did: I had a selection of multiple objects (37) including polylines (12), lines (19) and texts (6). After selecting those objects, I typed QSELECT in the command line to launch the 'Quick selection' tool. In the 'Quick Select' window, in the 'Apply to' dialog box, I chose the 'current selection' option. Then, I applied the following options to make the texts that I have in the original selection, meet these filtering criteria: In the "Object Type" dialog box, I selected the "Text" option; In the "Properties" dialog box, I chose the "color" property, followed by the "=Equal" operator, followed by the "ByLayer" value. All the texts I have in the original selection with the other objects have the 'ByLayer' color property. I selected the "Exclude from New Selection Set" option under "How to Apply", in order to exclude the texts that match the filtering criteria (which is 'equals to' 'ByLayer' 'Color'). I left the 'Append to Current Selection Set' option unchecked. Finally, I clicked OK to apply the filter and exclude texts from the selection of multiple objects. The result was that I don't have any objects selected, so I failed to exclude only texts from my original selection. I tried everything above, but checking the 'Append to Current Selection Set' option with the same result. What am I doing wrong?
Thanks a lot
