AutoCAD Forum
Programming inside AutoCAD
1 REPLY 1
autoid374ceb4990
148 Views, 1 Reply
Believe it or not I am still using R14 with a lot of programs that I wrote many years ago.  Most of my programming was using 'C' language to produce ARX programs.  Does the newest AutoCAD allow C or C++ programming?
Also another question - With the latest versions of AutoCAD, once the program is installed, do you have to online for it to operate properly?
1 REPLY 1
cadffm
in reply to: autoid374ceb4990
arx (C/C++) and Lisp are still available, also .NET
Online: You can use the program up to 30days offline, after the last online login.
Help2024 - DEV
https://help.autodesk.com/view/OARX/2024/ENU/
Sebastian
Forma Design Contest
AutoCAD Beta
