Beginner here and I've searched the internet until I was blue in the face for an answer to a seemingly straightforward problem. As part of an assignment, I need to make a macro that creates an octagon with edges that measure 8 units in length. Every time I use this macro:
^C^C_polygon;8;e;\;8<90;
I get an "invalid 2d point. Specify second endpoint of edge" error and need to manually enter "8" tab "90" or drag the cursor 8 units straight up to form the octagon. The macro registers the number of side I want and allows me to select the fist endpoint of the edge...then fails.
I'd appreciate any concrete. non-cryptic, help.
I have tried dozens of permutations (including -polygon) of the macro above and nothing gets me past the error
Solved by VincentSheehan. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
The @ is the key, needed for a relative displacement. Also, the \ for user input is complete by itself -- the ; after it is extraneous. And the ; at the very end is not needed -- Enter is assumed at the end unless the macro ends with a control character of some kind.
Another way:
^C^C_polygon;8;e;\@0,8
Here is a Lisp.
(defun c:OCTA (/ side angle radian step x y points)
(setq pt1 (getpoint "\nSelect point"))
(command "_polygon" "8" "E" pt1 "@8<90")
(princ)
@dpierson6B4ETP It appears you may not familiar with these for deliberate placement (see highlighted section)
Happy coding!
Just a dynamic input user who does not know, that it's not all relative by default.
You guys are the best! Thank you...I almost threw my laptop out the window!
