AutoCAD Forum
Octagon macro
7 REPLIES 7
Message 1 of 8
dpierson6B4ETP
371 Views, 7 Replies
Octagon macro
Beginner here and I've searched the internet until I was blue in the face for an answer to a seemingly straightforward problem. As part of an assignment, I need to make a macro that creates an octagon with edges that measure 8 units in length. Every time I use this macro:
^C^C_polygon;8;e;\;8<90;
I get an "invalid 2d point. Specify second endpoint of edge" error and need to manually enter "8" tab "90" or drag the cursor 8 units straight up to form the octagon. The macro registers the number of side I want and allows me to select the fist endpoint of the edge...then fails.
I'd appreciate any concrete. non-cryptic, help.
I have tried dozens of permutations (including -polygon) of the macro above and nothing gets me past the error
7 REPLIES 7
Message 2 of 8
ВeekeeCZ
in reply to: dpierson6B4ETP
Try this?
^C^C_polygon;8;e;\@8<90;
Message 3 of 8
The @ is the key, needed for a relative displacement.  Also, the \ for user input is complete by itself -- the ; after it is extraneous.  And the ; at the very end is not needed -- Enter is assumed at the end unless the macro ends with a control character of some kind.
Another way:
^C^C_polygon;8;e;\@0,8
Kent Cooper, AIA
Message 4 of 8
Here is a Lisp.
(defun c:OCTA (/ side angle radian step x y points)
(setq pt1 (getpoint "\nSelect point"))
(command "_polygon" "8" "E" pt1 "@8<90")
  (princ)
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 5 of 8
pendean
@dpierson6B4ETP It appears you may not familiar with these for deliberate placement (see highlighted section)
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-683349C0-E5C2-4E16-8846-5523E71172A9#:~:text=...
Happy coding!
Message 6 of 8
ВeekeeCZ
Just a dynamic input user who does not know, that it's not all relative by default.
Message 7 of 8
dpierson6B4ETP
in reply to: ВeekeeCZ
Thank you!  I was *this* close...I could have sworn I tried that.
Message 8 of 8
You guys are the best!  Thank you...I almost threw my laptop out the window!
Technology Administrators
