Problemas con desorden de las capas en control de capas
Buenas soy dibujante en arqueologia, y tengo un problema con las capas ya que cuando tengo mas de 1000 capas el control de capa las desordena, alguien sabe un comando para aumentar el numero de capas?
En arqueologia no es como arquitectura y debemos poner tres capas por estructura o hallazgo, por eso tenemos tantas capas
Alfred.NESWADBA
can you please describe why more than 1000 layers are handled incorrect?
AutoCAD does not have a layer number limit (at least not at 1000 layers)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
The clutter appears here in the layer control, the layers do not come out in order, and it happens to me when I have more than 1000capas.jpg
Alfred.NESWADBA
Ok, please change the sysvar (type it into the command line followed by <ENTER>)
MAXSORT
and raise the value you have currently, after that close and restart AutoCAD.
More details about MAXSORT: >>>click<<<
- alfred -
Alfred NESWADBA
Thank you very much, it is already solved
