command input delay
command input delay
command input delay
For seven years I've used AutoCAD2011 on my Dell Intel Xeon CPU/w3565@3.2, 18GB Ram, 64x.  AutoCAD has worked great for years. This past two-ish years the commands were slow to be executed. The delay produces the thinking wheel and diminishes my productivity. I upgraded the video card to NVIDIA GeForce GT730. Not the solution. In desperation, I purchased a new computer, DELL Precision 5820, Xeon W2125@4.0, 32 Ram, NVIDIA QUADRO P2000. Hmm, not as slow (no wheel) but delay is still there - productivity is still low for the $ spent. Blogs have suggested to turn Dell Precision Optimizer to OFF and AutoCAD Hardware Acceleration to OFF. Not the solution. What is the problem? Is it Windows10Pro? Or am I at the point I must buy new AutoCAD?
injineri
I had problem with keyboard input delay and when docked the command line below, afer that seems that inputing working faster. hope that will help.
Alfred.NESWADBA
Are you running AutoCAD 2011 on Windows 10, then yes, that might be a problem as AutoCAD 2011 was released long (very long) before Windows 10 was introduced/released.
Hope you use this workstation also for other products, not just AutoCAD ... as the Xeon processor has a lot of kernels, but AutoCAD (as most CAD applications) mainly work on just one of them. An i5 or i7 with a higher frequency would be the better choice for AutoCAD.
..or are you on a newer AutoCAD release and we can suggestion to look into the "input search options"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I docked the text screen which made a huge huge improvement in speed.  I'm still flummoxed that this was the solution.
Thank you! Thank you! Thank you!
