I am working on Autocad for many years but this time that i installed again Autocad in a new PC, i face an unexpected problem:
I am configuring all parameters in order to print a drawing in a A3 size paper and what comes out is a drawing that is cut! When i preview the drawing, everything seems ok but when the it is printed it comes out cut (the scale comes out o.k). I am attaching a screenshot.
I noticed that despite the fact that i have assigned the proper paper size in the plot window, in the plotter configuration editor's window the paper size isn't correct (and it can't be modified, because every time i am doing it, it returns to A4).
Any suggestion will be much appreciated.
Thank you pendean for your answer.
Unfortunatelly, this is not the case (i tried but it didin't work).
I suppose that the problem has to do with the printer (probably its driver) and not with Autocad's plotting settings..., but i can't find out how it can be solved.
If there is any other kind of idea/suggestion, it will be welcome.
