Anonymous Block ATTBLOCKREF or BLOCKREF Object Menu
TomBeauford
Advisor Advisor
Message 1 of 16
TomBeauford
Right-clicking an Anonymous block will not bring up either ATTBLOCKREF or BLOCKREF Object Menu. Is this a bug? Any workaround?
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
It can't be an anonymous block.
Message 3 of 16
TomBeauford
According to properties it's an anonymous block with one attribute. It's created by Autoturn software which runs as an AutoCAD plug-in. I have a lisp that converts it to a named block in both the ATTBLOCKRE​F and BLOCKREF Object Menus. Right-clicking an Anonymous block will not bring up either one.
2023
Message 4 of 16
TomBeauford
Had to update my signature, this is happening on Civil 3D 2015.
2023
Message 5 of 16
pendean
Community Legend
Community Legend
You may have misunderstood: I'm not doubting it is an anonymous block, I believe the commands/tools you want to use do not operate on those types of blocks.
And you probably need that add-on to recreate the block.
Message 6 of 16
TomBeauford
The command works great, that's not the issue. The problem is "Right-clicking an Anonymous block will not bring up either ATTBLOCKREF or BLOCKREF Object Menu." The ATTBLOCKREF and BLOCKREF Object Menus work as expected for regular blocks.
2023
Message 7 of 16
pendean
Community Legend
Community Legend
Exactly: your anonymous block is NOT a "regular" block. That's the problem, it needs to be a "regular" block first.
Message 8 of 16
TomBeauford
So your answer to the original question is that those right-click shortcut menus aren't supposed to work with anonymous blocks.
Is it possible to create a right-click shortcut menu for anonymous blocks?
2023
Message 9 of 16
pendean
Community Legend
Community Legend
Correct: the best approach would be to turn your anonymous block into a 'regular' block instead. There are many free lisps to do that, and a freeware at dotsoft.com called BLKRENANON.VLX that should do it too.
This is assuming your anonymous block is not a Dynamic block: then you're best off fixing it with BEDIT command instead.
Message 10 of 16
No... Autocad cannot edit anonymous blocks that were created by a 3rd party add-on.
Message 11 of 16
TomBeauford
AutoCAD cannot edit any anonymous blocks I have a lisp to give them names.
Lots of random replies here, but does anyone have an answer to the question?
2023
Message 12 of 16
Since this is peer to peer.....
Sent from my iPhone
Message 13 of 16
Sent from my iPhone
Message 14 of 16
TomBeauford
Is there anyone who could provide an answer related to the question?  Is it possible to have a right-click menu for an Anonymous block?
2023
Message 15 of 16
Alfred.NESWADBA
AFAIK ... NO, not possible (without development).
And when an application developer creates anonymous blocks then that has reasons for his workflow ... you might crash the app when start to make modifications to these block-insertions.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 16 of 16
TomBeauford
Thanks! Only entity I haven't been able to create one for. I've assigned names to them the past 15 years with lisp. Would have made it easier, but I've gotten by without it all these years.
2023
