AutoCAD Forum
problem with some layers
5 REPLIES 5
yossi480
266 Views, 5 Replies
i have some issue with some layers. in some of them i can only see dots where the grips are instead of full lines.
the problem isn't with the drawing. everythung is ok when i open it on another pc. i think its a settings matter.
thanks for the repliers.
5 REPLIES 5
TheCADnoob
in reply to: yossi480
Is it a standard line type? If not, can you change it to a standard line type temporarily and see if it behaves as you would expect.
CADnoob
Valentin-WSP
@yossi480 ,
Welcome to the AutoCAD forum!
Compare your support path from the other computer.
These links may provide more help:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
paullimapa
could be your computers graphics driver not being 100% compatible
try this setting first: GFXDX12 = 0
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-make-AutoCA...
If that doesn't work enter command GRAPHICSCONFIG and under 2D Display Settings select Intermediate:
If that still makes no difference disable Hardware Acceleration
Paul Li
IT Specialist
@The Office
yossi480
in reply to: paullimapa
the gfxdx12=0 did it! thanks.
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Forma Design Contest
AutoCAD Beta
