AutoCAD Forum
Problem with missing SAVEAS dialog box
4 REPLIES 4
999 Views, 4 Replies
Seem to be having issues with missing FILE SAVEAS Dialog box.
Have tried FILEDIA, and it is set to '1'. But still does not work.
Any Suggestions?
Cheers,
4 REPLIES 4
Patchy
It came up with a prompt or not? if it's not, your dialog box might be off the screen.
in reply to: Patchy
It took a bit of mucking around but it seemed to restore itself after I reverted to single monitor display. Then I was able to go back to extended displays over 2 monitors.
It looks like the 'dialog box' was off screen beyond what the monitor could display.
Thanks to Patchy for the response.
Neil47
If it happens again try placing the cursor over the taskbar, right click and select Cascade Windows. The dialogue box will close when Windows carries out the command and when you next use Saveas the dialogue box will appear central to the monitor.
Thank you for mentioning the FILEDIA being set to "1".  That just solved the problem for me!!
AutoCAD Inside the Factory
