07:42 AM
For some reason that I can't figure out, Autocad has started making all my dimensions using my "door layer" (yellow), even though my "dimensions" layer (magenta) is selected in the pull-down menu and in the layout settings. I can, however, select the dimensions after I create them and set them to the correct layer.
This started in another project with multiple sheets yesterday. I've since saved that file as a new file for a new project, which I'm attaching.
I was also experiencing what seemed to be some other bugs with hatching right before this issue started, so I'm not sure if there's a problem with my program or if it's a user error.
Thanks for any advice.
