Seem to be having issues with missing FILE SAVEAS Dialog box.
Have tried FILEDIA, and it is set to '1'. But still does not work.
Any Suggestions?
Cheers,
It took a bit of mucking around but it seemed to restore itself after I reverted to single monitor display. Then I was able to go back to extended displays over 2 monitors.
It looks like the 'dialog box' was off screen beyond what the monitor could display.
Thanks to Patchy for the response.
If it happens again try placing the cursor over the taskbar, right click and select Cascade Windows. The dialogue box will close when Windows carries out the command and when you next use Saveas the dialogue box will appear central to the monitor.
