Because AutoCAD 2017 is already installed. Look for acad.exe in the following location: C:\Program Files\Autodesk\AutoCAD 2017
Once you find it double-click it to launch the application.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Now I understand. You'll need to manually uninstall the software. To do this, see the link Manual Uninstall in my signature under Resources. This will guide you through the process of using Microsoft Fixit to remove the application data behind the scenes so you can reinstall it.
Darin Green
