Problem with associative leaders
Message 1 of 16
Hi everybody.  i´m doing a presentation of a 3D model in paper space and i want to use leaders to point equipments but i´m having 2 problems.
1-Leader desapears after i write the text when i snap a point of the model, but if i start de leader with out snaping any point it stays.
2- The second problema its that the leader that i make wothout snaping any point it´s not an associative leader and it doesnt let me reassociate to any point.
any ideas why?  im using autocad 2016
Replies (15)
Message 2 of 16
ennujozlagam
Can you use Qleader command and set your Dimaso to 1. Thanks
Message 3 of 16
it still keeps "no" associative, im using leaders in a viewport with a 3D shaded mode 3D model
Message 4 of 16
murray-clack
Try setting DIMASSOC to a value of 1
FYI...
DIMASSOC = 0 (makes exploded dims and leaders)
DIMASSOC = 1 (makes non-associative dims and leaders, which means they stay intact but are not associated to the object being dimensioned)
DIMASSOC = 2 (makes associative dims and leaders, which means they are associated to the objects being dimensioned in that if the object changes, the dims and leaders also change)
Message 5 of 16
Sofia.Xanthopoulou
Hi @Anonymous,
I have tried to recreate it. Neither does my leader disappear nor is it disconnected from the model, when I move the view. Except, I did something else then you did.
It may be beneficial if you could send a screencast, showing your steps and the results.
Message 6 of 16
Sofia.Xanthopoulou
Just checked my DIMASSOC is on 2.
Regards
Message 7 of 16
My DIMASSOC is in 2 also.
this is what happens.
Message 8 of 16
Sofia.Xanthopoulou
This is when you open this drawing which has already the leader in it? Or did you create them and at the next moment you lose the associative connection?
Can you please upload the drawing? Or maybe a smaller one? BTW does it happen to all your drawings or this particular one?
Regards
Message 9 of 16
it happens only in this particular file, when i start drawing the leader and lose it, as a matter of fact when i draw a leader from some point of the model and then lose it, the leader desapear, it doesnt stay in the drawing, so i have to draw the leader from any point and then move it to where i want to point to.
Message 10 of 16
Sofia.Xanthopoulou
Could you export the drawing with wblock to have it purged and then create the views again. See how it reacts then...
Regards
Message 11 of 16
Sofia.Xanthopoulou
Hi @Anonymous,
have you tried the suggested steps with the wblock? Did it make any difference?
Any feedback will be appreciated Smiley Happy
Message 12 of 16
hi, i did a copy paste of the drawing in a new file and it worked out well.
thanks for the help ¡¡
Message 13 of 16
Sofia.Xanthopoulou
Well, then glad to hear it work out Smiley Happy
Please mark your post as accepted solution so that other reader can benefit from your experience.
Thank you for your contribution
Message 14 of 16
Thanks for the help and the validation of my post as accepted solution, as you could see im drawing part of a process plant, im thinking on migrating to plant 3d or inventor (i prefere inventor, but plant 3d its easy to learn) what would you recomend me??? its not only pipping its equipment to.
Message 15 of 16
Sofia.Xanthopoulou
You are welcome Smiley Happy
As for your question on which software to use...
Well, I do not know Plant 3D - I am an Inventor girl Smiley Wink so I am not impartial enough to give advice. From what I see, your drawings are realizable in Inventor. And this is how far I can go.
But whatever you decide the community is here to support you Smiley Happy
Good luck
Message 16 of 16
thanks, im also more fan of inventor so, i will get in to it.... thank you a lot ¡¡
