AutoCAD Forum
Problem not displaying ECW Raster image in Viewport Layout when I rotate the map with the Alignspace command
4 REPLIES 4
Oliver_C3D
570 Views, 4 Replies
Hi Dears
ECW Raster Image is not displayed when I recently rotate the map with the Alignspace command in the Viewport Layout.
where is the problem from?
Thanks dears
4 REPLIES 4
Valentin-WSP
in reply to: Oliver_C3D
@Oliver_C3D ,
Check this link:
https://forums.autodesk.com/t5/civil-3d-forum/plot-ecw-image-in-viewport/m-p/9400940#M421295
Check your SHADEMODE = 2d.
Attach your raster by reference, instead of pasting it from a clipboard.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
ben.saa
in reply to: Valentin-WSP
Try the following:
Re-embed the image into the drawing OLE image usually stick in place
  1. Open the image in Microsoft Paint
  2. Press CTRL-A and then CTRL-C to select and copy the image.
  3. In AutoCAD, use the PASTESPEC command.
  4. Select the option "Image Entity."
Oliver_C3D
My photo has ECW coordinates and I imported it through mapiinsert. I did this with larger ECW several times before and I had no problem, but this is the first time it does not show the photo in the viewport layout!!!
@ben.saa
@Valentin-WSP
Valentin-WSP
@Oliver_C3D ,
Emilio Valentin
Forma Design Contest
AutoCAD Beta
