Hi Dears
ECW Raster Image is not displayed when I recently rotate the map with the Alignspace command in the Viewport Layout.
where is the problem from?
Thanks dears
Solved by Valentin-WSP. Go to Solution.
Check this link:
https://forums.autodesk.com/t5/civil-3d-forum/plot-ecw-image-in-viewport/m-p/9400940#M421295
Check your SHADEMODE = 2d.
Attach your raster by reference, instead of pasting it from a clipboard.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Try the following:
My photo has ECW coordinates and I imported it through mapiinsert. I did this with larger ECW several times before and I had no problem, but this is the first time it does not show the photo in the viewport layout!!!
