AutoCAD Forum
printing problem a4 size
4 REPLIES 4
725 Views, 4 Replies
Dear respected,
whenever i am printing my dimension text is coming hollow please guide where i have to change properties
Please find in word attachment while printing on a4 size paper it is exactly coming like that
i want that text to be filled
Thanking You
4 REPLIES 4
Alfred.NESWADBA
that is what I get when using "DWG to PDF.pc3" to plot to a PDF file.
Can you try the same? When looking then to your PDF are the fonts filled or not.
Also please verify that FILLMODE is activated.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Dear Sir,
not in dwg to pdf
when i am printing in a4 size paper Text is coming in wire frame
My printing properties is correct or no please tell me and please find attachment how the output print
please see the docx file
please giude me the steps to get filled
thanks
Alfred.NESWADBA
when your PDF looks good, then open the PDF and send it to the printer, does that show then filled text?
If not, have you tried to activate the systemvariable FILLMODE?
- alfred -
Alfred NESWADBA
yes i have tried fillmode nothing is worked out and also i had converted dwg to pdf then tooked printout its working
but before it when i use to to print on paper this problem was not showing off
anyways thank you
AutoCAD Inside the Factory
