Installation error Message (Please Insert Disk 1)
Hello, My name is Luke and I have a College class on AutoDesk.
When I downloaded the software my ASUS didn't have enough storage space (even after clearing everything off of it) so i bought a 32gb PNY USB 3.0 to use as storage for the software. When installing the program the error message came up telling me to insert disk 1, which i don't have because it was an online download. I need help!
Patchy
Burn the discs or get external program to install it.
https://www.youtube.com/watch?v=YmED82_fhrQ
i watched the video and i was able to add the "USB_REMOVABLE" to the setup file, but I got lost after that, can you help explain what to do next
edwin.prakoso
This is for Inventor, but the solution is the same for AutoCAD: https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Cheers,
Edwin Prakoso
One other way to go about it is to unzip the disc file and go on about it like you would usually do, you wouldnt need to edit anything in the setup file.
