AutoCAD Forum
PressPull froze AutoCAD
4 REPLIES 4
374 Views, 4 Replies
I needed to test the 3d printer so I took our school mascot (Go Bobcats!), imported as a 2d image, and started extruding using PressPull. Once I got half way done extruding, AutoCAD froze. I tried updating, force quit and restarting, and didn't find any limitations on licenses.
Any solutions welcome
4 REPLIES 4
Patchy
Can you save it down to 2007 format?
JDMather
What do you see if you do a Zoom All?
Try this.
Right click on View Cube set to Parallel rather than Perpsective.
Zoom All
Rotate around a bit.
Zoom All again.
Click on the Top view of the view cube.
See anything unexpected?
Get rid of it if you do.
Union
select all.
pendean
This is your posted file, I just opened it and zoomed out to have a better look
JDMather
in reply to: pendean
This is what I see.
Also, when I try PressPull (the problem description) - not expected behavior.
Until I follow the steps I suggested earlier.
Model (image you posted) is wayyyyy down there....
But without any feedback from the OP....
Forma Design Contest
AutoCAD Beta
