AutoCAD Forum
Porblem selecting text in paper space
11 REPLIES 11
Message 1 of 12
M.Lindell
1021 Views, 11 Replies
I have text in paper space and if I try to select it on first click it starts area selection and I have to click second time or press ESC to finally select text.
To edit text I have to doubleclick twice (first to select and second to edit).
This happens only in paper space if TEXTGAPSELECTION is set to "1". If it's set to "0" everything works normally.
What would be the problem here? I would like to keep TEXTGAPSELECTION set to "1", but it's a bit annoying in paper space. I'm using AutoCAD 2021 on windows 10.
Labels (2)
11 REPLIES 11
Message 2 of 12
imadHabash
in reply to: M.Lindell
i suggest to make a small screencast that will help us more to understand your issue ?
Imad Habash
Message 3 of 12
M.Lindell
in reply to: imadHabash
Here's the screencast
Message 4 of 12
M.Lindell
New try with screencast:
Message 5 of 12
RobDraw
Cannot recreate the problem by changing TEXTGAPSELECTION.
Can you share the problem file?
Rob
Message 6 of 12
imadHabash
would you turn OFF your hardware acceleration from GRAPHICSCONFIG command , any changes ?
Imad Habash
Message 7 of 12
M.Lindell
No changes if hardware acceleration off....
Message 8 of 12
imadHabash
in your previous screencast i noticed that your below icon for hardware i turning OFF and ON !!!
if you don't mind ... waht happen if you change your mouse with another one ?
Imad Habash
Message 9 of 12
M.Lindell
The harwarea acceleration icon seems to turn dim during area selection. No idea why.
(in model space too)
Tried different mouse and it's the same.
My collague doesn't have this issue so I think I'll reinstall.
Message 10 of 12
RobDraw
Make sure to follow Autodesk's directions on doing a full uninstall.
Rob
Message 11 of 12
imadHabash
how about Install the latest driver for the graphics card in the system . >> Click <<
Imad Habash
Message 12 of 12
M.Lindell
@imadHabash @RobDraw
I may have figured out what caused the issue.
I had PICKAUTO set to value "7". This combined with TEXTGAPSELECTION = "1" caused the problem.
 - Changing the PICKAUTO to 5 in 2021 version fixed the issue.
In 2022 version I couldn't recreate this issue.
AutoCAD Inside the Factory
