Offset Input Tab/Palette
j_winkleman
j_winkleman
Looking to create a tab or a palette that I can set commonly used measurements so I do not have to manually input each time I offset.  Example, I commonly use a .8125" offset (among several others).  Would like to be able to point, click, offset the line.  Any ideas??
Kent1Cooper
That's very basic macro territory.  You can make macros with contents like this:
^C^C_.offset 0.8125
in Tool Palette buttons.  That will set the distance and just leave you in the command to continue.
Or, you may be interested in >this<.
Kent Cooper, AIA
j_winkleman
Awesome!  Much appreciated!!!
