I have text in paper space and if I try to select it on first click it starts area selection and I have to click second time or press ESC to finally select text.
To edit text I have to doubleclick twice (first to select and second to edit).
This happens only in paper space if TEXTGAPSELECTION is set to "1". If it's set to "0" everything works normally.
What would be the problem here? I would like to keep TEXTGAPSELECTION set to "1", but it's a bit annoying in paper space. I'm using AutoCAD 2021 on windows 10.
Solved by M.Lindell. Go to Solution.
Solved by RobDraw. Go to Solution.
i suggest to make a small screencast that will help us more to understand your issue ?
Imad Habash
Cannot recreate the problem by changing TEXTGAPSELECTION.
Can you share the problem file?
would you turn OFF your hardware acceleration from GRAPHICSCONFIG command , any changes ?
Imad Habash
in your previous screencast i noticed that your below icon for hardware i turning OFF and ON !!!
if you don't mind ... waht happen if you change your mouse with another one ?
Imad Habash
The harwarea acceleration icon seems to turn dim during area selection. No idea why.
(in model space too)
Tried different mouse and it's the same.
My collague doesn't have this issue so I think I'll reinstall.
@M.Lindell wrote:My collague doesn't have this issue so I think I'll reinstall.
Make sure to follow Autodesk's directions on doing a full uninstall.
@imadHabash @RobDraw
I may have figured out what caused the issue.
I had PICKAUTO set to value "7". This combined with TEXTGAPSELECTION = "1" caused the problem.
- Changing the PICKAUTO to 5 in 2021 version fixed the issue.
In 2022 version I couldn't recreate this issue.
