polyline grips popup menu disappears
yulia02801
Message 1 of 9
yulia02801
 when i hover a grip on the polyline to add vertex the popup menu appears but as soon as the cursor leave the grip ,the menu disappears!
the monitor is 4 k
display scale : 175%
it was working well till i overrode the DPI by "system "   but the words , letters and numbers  were very big and icons were tiny
and i ain't wanna change the resolution
autocad 2017
Replies (8)
Message 2 of 9
imadHabash
>> display scale : 175% <<
i suggest to reduce the display scale of the screen to 100% .
Imad Habash
Message 3 of 9
Alfred.NESWADBA
>> autocad 2017
Which update/service pack do you have installed? Start command _ABOUT, there you can see the exact version, should be 2017.1.2 ==> this supports DPI-scaling and so your issue with disappearing popup should be solved.
Also necessary to verify: which graphic card do you have and which driver version? Please start command _GRAPHICSCONFIG and show us the screenshot from that dialog.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 9
yulia02801
can you imagine the display scale of 100% on 15'' monitor ?
it's imposible
Message 5 of 9
yulia02801
 hi,
Message 6 of 9
pendean
Community Legend
Community Legend
You need to be running AutoCAD 2017.1.2 version: use ABOUT command to confirm what you have then install the required updates.
Or move to AutoCAD 2018 or AutoCAD 2019 which have better hi-res monitors support.
But.... running AutoCAD on a 15" screen was an unwise purchase to begin with either way.
Message 7 of 9
yulia02801
 i already updated cad to 1.2 version
and it's a laptop so all i have would be a 17" monitor at best  and certainly it's not enough for 4k display
Message 8 of 9
pendean
Community Legend
Community Legend
You wrote 15" on a earlier response... . Not sure? Need a tape measure?
As a test, only a test, if your display was set at 125% (or 100%) scaling does the problem go away? Find out for sure because no one at Autodesk is going back to fix R2017 on high-res monitors anymore since they want all of us using R2019 now.
Message 9 of 9
yulia02801
saadallah ,
what i wanna say is that it's a laptop and at best cases you will have 17" instead of 15" _which i have _
and it isn't a big difference
display ratio 100% is shrinking icons ,words ,apps display window   to less than  1/3 !
oh , thank you for your efforts to solve a R2017 prob.
