I am having a problem creating PDFs they are not centered on my page. I know how to do it but for some reason even after going to the page setup manager and changing the settings the PDF is still printing incorrectly. Here are the steps I am taking to create the PDF and then the steps I am taking to correct the problem. After plotting I am still off center.
1. Open sheet set
2. Open (1) sheet
3. Right click File Name
4. Publish to PDF
5. Page set up manager sets are screen shot and the end product is shown.
Solved by john.vellek. Go to Solution.
To answer your question yes of coarse it needs to be printed, We submit the sets to different jurisdictions for permitting. The template has always fit on an 11" x 17" sheet so I know the content isn't to large for that sheet size and the adjustments shown in the screen shots are what I used before to make the files fit. I was using Auto CAD (Full Version) and my company recently switched to the Electrical version. I did correct the issue by using ANSI B 17" x 11" expand, but it still isn't perfect. It sits low on the page. Fit to paper doesn't work either.
OK, rather than layout, can you choose a window and put that round what you want to plot? With that and scaled to fit it should work ok
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
If you can attach a sample file as well as a titleblock and your pen settings, I would like to take a look at your issue. Please let me know if these files can be attached to a post. If not, you can send them directly to me at john.vellek@autodesk.com.
Hi @Anonymous,
Here is a summary of what we explored on your plot to PDF issue:
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
man that is what I have chosen to run with and it is working great. I set up all of my templates with that format and we are having no issues. For some reason my PDFs still aren't printing the gen notes the way I want and I have messed with the pin settings. I am still working on that put the DWGs are PDFing with no issues and they are centered so thank you.
Hi @Anonymous,
I am glad that this is working well for you. If you want to send me your plot styles I can take a look for you to see what else might be improved for your General Notes.
(I might also need your dwg file again)
Thanks for helping with the pen settings , If I have any questions in the future I willl be sure to ask.
