I am using Civil 3D 2019 (autocad 2018). I have a file with a large amount of MTEXT.
The original data source for the MTEXT is PDF files, which were saved back to MS Word .docx format using Bluebeam PDF. The converted .docx file has a file size of 329 KB.
I had to use the pastespec command due to some formatting issues in the .docx file, which were not apparent until the text was pasted into the MTEXT editor. After doing this, the resulting .dwg file (containing around 90 layouts) is around 2.3 MB.
However, when I plot back PDF using any of several PDF plot devices, the resulting PDF file is around 150 MB. The sheets containing the MTEXT are definitely the culprit, with each of those sheets having a file size of around 7-8 MB.
The .docx file is only 329 KB, as stated in my post. When the text from the .docx file is pasted into the MTEXT editor, the resulting file size (2.3 MB for the entire 90 layout file) is also not abnormally large. When that .dwg file is plotted from autocad using various PDF plotters, the sheets containing this MTEXT are abnormally large (7-8 MB).
I was including the information concerning the source of the MTEXT and its inherent formatting issues because I suspect this may not be a pure autocad issue.
Why not importing the PDF into AutoCAD (instead of PDF ==> Bluebeam ==> DocX ==> Word ==> copy & paste)
- alfred -
As a test, I created a full sheet of generic (manually typed) MTEXT and the resulting sheet size was 600 KB.
The issue was apparently due to the text oblique angle of 15 degrees. Resetting the oblique angle to zero and using italicized text within the MTEXT editor yields a PDF plot size of around 200 MB. Weird.
