AutoCAD Forum
Drawing units
3 REPLIES 3
1096 Views, 3 Replies
Drawing units
I started a blank autocad drawing, now how to change the units of this drawing to mm?
All I saw about setting units was when I click Autocad icon at the very top left, then I click options, then under user preferences tab there is an insertion scale which was in inches and I made it mm.
But this means my drawing is in mm now or what? If not from where can I make sure I am drawing in mm?
I mean for example when I am drawing a line, and when type 5 for length, i want it to mean 5 mm. and so on...
Drawing units
3 REPLIES 3
pendean
pendean
Community Legend
Community Legend
-DWGUNITS command, follow the prompts at the commandline.
Alfred.NESWADBA
Alfred.NESWADBA
If you started with ACADISO.DWT then you are on Millimeters, you can start command _UNITS to verify that.
These 2 settings are only valid if your current drawing file and a different dwg-file from which you want to insert objects is set to "no units" (which I would avoid).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
rkmcswain
rkmcswain
At the most basic level, in AutoCAD and probably any other CAD program, when you draw something 5 (units long), that 5 can be mm, inches, feet, yards, miles, light years, or even some fictional unit of measure. True, there are some tools designed to help users deal with specific units, but even if you did nothing, your "5" can certainly be 5 mm.
R.K. McSwain     | CADpanacea | on twitter
AutoCAD Inside the Factory
