AutoCAD Forum
Plotting freezes the system
6 REPLIES 6
6459 Views, 6 Replies
I have a simple 2D drawing with minor hatches, no attached pdf or images.
Whenever I try to plot, it just freeze the computer just after you sent it to the plotter indicating it's regenerating sheet.
Please see attached screen shot. Nothing output from printter at least 15mims or more, but the plot job is in the plotter que.
However if I plot any other drawing, the plots are out in seconds.
This is plotting at layout Paperspace and it happens on every layout.
I tried using another system in totally different location/offices, it freezes similarly.
There is no issue with other drawing except this. With that I think is not related to the CTB file.
AutoCAD 2015/2016.
Your advise is most appreciated.
mcmk8
AutoCAD 2015/2016.
mcmk8
6 REPLIES 6
Attached is the drawing. It freezes when you sent the plot for any layout. However there is no issue when plot to PDF.
I have experienced that EXACT same problem and I am still curious of a solution.
pendean
pendean
Community Legend
Community Legend
Is the problem you have only with one file, or ALL files? If only one file, INSERT it into a working template file, recreate all the layouts from scratch and the issues should go away.
The file above in the old post you are replying to uses a lot of linear gradient hatches (that are not set to look gradient for some reason on my screen anyway) and these are slow to plot. if that's your problem, that's the price you pay for gradient hatches. It plots eventually, it took a full minute to get a PDF from it here just now, Layout5.
TheCADnoob
TheCADnoob
In EXTERNALREFRENCES there are two un-referenced files and one missing one.
Try removing the un-refrenced ones and try binding the the missing one or removing it if you dont need it. It may be trying to resolve the external reference before printing.
CADnoob
CADnoob
in reply to: pendean
After having said that, I noticed that the drawing I am working has a little gradient hatching. I have never worked with it before making sense why this is the first time I have had such a problem plotting.
Thanks guys. Gradient hatch was the problem.
AutoCAD Inside the Factory
