Plotting error
Plotting error
Plotting error
I am periodically getting the attached error when plotting. It doesn't happen all the time and isn't restricted to a particular drawing, mostly if i close and re-open the drawing it will plot with no problems but today it has refused to plot at all on one drawing, (which i plotted fine yesterday afternoon) on any of the 3 plotters, although it will happily print to the photocopier!
I have looked into it a bit and it seems to think there is a driver problem, but I'm not sure i believe that as it works 90% of the time, so...any ideas?
john.vellek has embedded your image(s) for clarity
imadHabash
from PLOT dialog select your Printer/Plotter that end with .pc3 , try and  see if it's fixed .
Imad Habash
john.vellek
Hi @Anonymous,
I am curious to see if you checked the one drawing for errors with AUDIT.  Do you also have a named PageSetup applied?  Can you print this one file to an AutoCAD PDF?
If you can share the file I am happy to take a closer look at it  for you.
John Vellek
Today it's a different drawing, the one yesterday plots with no problems!!
i have run an audit with no errors and yes, it will print to PDF.
EDIT: closed the drawing and re-opened for the 4th time, for some reason it's plotted with no errors now.
john.vellek
Hi @Anonymous,
This could be as simple as a bad layout.  Which version of driver are you using? Are you using PCL5?
John Vellek
