An update was performed, now when trying to use PLINE it stays perpendicular to any point I am snapping to. Any help would be greatly appreciated as I've never seen this before.
Solved by GrantsPirate. Go to Solution.
I just tried multiple files and the issue is on each of them. I tried going through osnap settings to see if maybe I selected something on accident but that isn't the case either. The drawing I'm working on is super simple, essentially I am connecting data point dots using pline that I will then make into a region. These dots are not in a straight line but pline will only go horizontally.
I apologize for the confusion, I just realized I posted in ACAD 07/08/09, I'm using 2016!! Do I need to repost there or can this thread be moved?
@Anonymous wrote:An update was performed, now when trying to use PLINE it stays perpendicular to any point I am snapping to. Any help would be greatly appreciated as I've never seen this before.
Is ORTHO on?
Just in case, set UCS to World, and Plan to World.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks, I must have accidentally clicked on something around the UCS/World control wheel. Never done that before!
