AutoCAD Forum
pline glitch
5 REPLIES 5
Robertm0077
538 Views, 5 Replies
pline glitch
what causes the plines to show like this large arrow head? a regen fixes the issue, but it slows down drafting having to do the extra command.
5 REPLIES 5
alex101000
in reply to: Robertm0077
Please share a fragment of the file with the problem area.
Is there a problem with this new file?
Robertm0077
in reply to: alex101000
File is attached.
neaton
If it is fixed with a regen then it is most likely a display issue. Is the latest driver installed for your graphics card?
Nancy
alex101000
In similar cases, it is recommended to disable hardware acceleration, install all AutoCAD updates and hotfix.
Robertm0077
issue solved, thank you!
AutoCAD Inside the Factory
