Please Convert DWG Part to STP for Me!
Message 1 of 12
Would someone please convert my attached DWG part to STP? I would be very grateful; I only have AutoCAD 2009.
Replies (11)
Message 2 of 12
Alfred.NESWADBA
Please find attached (without warranty 😉 )
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 12
Thanks so much, Alfred; that's very kind of you! I noticed some glitches in my STP viewer. That type thing may be pretty common with these conversions.
Message 4 of 12
Alfred.NESWADBA
That's what I get when importing the STEP-file that I have sent you:
- alfred -
Alfred NESWADBA
Message 5 of 12
Oh, Okay, Great. I suppose that the problem is with my STP viewer.
Thanks for your help!
Message 6 of 12
Would someone be kind enough to convert the attached .dwg file into .stp for me - I'm on Autocad 2013!
Many thanks
Message 7 of 12
Apologies - now attached in .dwg
Message 8 of 12
mgalicki
Alfred,
I am taking a Navisworks file & exporting to an FBX file.
Then converting to a DXF file and I get a 3D file but it's tons of what appear to be individual surfaces.
This file ends up being huge in size.
Is there a way to end up with a solid?
Thank you,
Mark
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Message 9 of 12
Alfred.NESWADBA
...should be a new thread as this new questions does not fit to the current thread title (DWG to STP...)
Maybe the admin moves that post ...
That is a lot of conversion and before we start to analyse this workflow please let us know what the source of the NavisWorks project is.
NavisWorks is not a construction software, it does not create geometry, it only shows data from imported files. So which file-type was the one you imported, which software was used to create that data ... and there we will start (otherwise the first conversion <ThisSoftware> to NavisWorks has already destroyed some infos and we start with the first errors).
- alfred -
Alfred NESWADBA
Message 10 of 12
mgalicki
the original was PDMS.
I don't have PDMS:(  $$$$
I exported the file to a FBX.
Then I converted the FBX file with Autodesk FBX to DXF conversion pkg.
I used Autodesk plant 3D to import the dxf
Thank you
Mark
Autodesk MEP 2019
Message 11 of 12
Alfred.NESWADBA
Ok, I don't know PDMS ... which types of geometry can they export (I assume you have contact with the creator of that project files)?
Are you expecting to import the data as Plant3D object model? Then I guess you can't do that when FBX is part of the conversion process ... all object informations (besides of material and color) are lost in FBX
If you only need to display the geometry to do some connections/additions to the existing project why not using the NWC file to attach it to your dwg (command _COORDINATIONMODELATTACH) or create a 3D-DWF file from NavisWorks and attach it to your dwg (Sorry, DWF can only be attached as 2D DWF/DWFx)?
- alfred -
Alfred NESWADBA
Message 12 of 12
mgalicki
Thanks Alfred.
Unfortunately we can't get the owner of the PDMS model to export the model to neutral files for us:(
I am currently exporting isolated pieces of equipment to an FBX file then converting to a DXF.
The serious draw back is the file is in mesh style with thousands of entities.
And it's difficult to apply nodes to snap to on the items.
So I'll try  your idea & let you know how it turns out.
Thank you.
Mark
Autodesk MEP 2019
