AutoCAD 3D Commands
AutoCAD 3D Commands
kcol-kkc
Message 1 of 10
AutoCAD 3D Commands
kcol-kkc
I am teaching myself 3D design in AutoCAD Civil 3D 2017.  Civil 3D is what's available to me so that's what I'm using.
I have been creating shapes and then using the STLOUT command to export it as an .stl file.
I then load the .stl file into Slic3r to prepare it for printing on a 3D printer. I have been having a huge amount of difficulty with this.  Finally I have discovered that the object I open in the .stl file is only 1mm high.  I drew it over an inch high.
So why is my object. Drawn at a 1:1 (I think) in AutoCAD. Being squeezed down to 1 mm in thickness?  My Units? Scale?
Any help would be greatly appreciated.
Also it's the end of my day and the end of my workweek so I won't be checking this until Monday.
Thanks in advance for the help.
Replies (9)
Message 2 of 10
john.vellek
Hi @kcol-kkc,
Can you share the model? I would like to try exporting it to an STL and then look at it in Inventor or Fusion 360 to verify the dimensions are correct.
John Vellek
Message 3 of 10
kcol-kkc
Absolutely.
Message 4 of 10
Model looks ok, settings appear right unless i've overlooked something, did a round trip through STL to DXF and back in DWG and got back what I sent to STL.  (I did UNION the solids into one solid first, cuts down on "seams" in the final product.
I'd say there is a unit setting at the 3dprinter side that is set to mm instead INCHES.
Message 5 of 10
Alfred.NESWADBA
an STL file does not know "units", it exports the value as it is - as number without a unit definition.
How that number is interpreted (as Inch or Millimeter in most cases) is part if your slicer software. Or you have to use your slicer software to scale the model before printing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 10
john.vellek
Hi @kcol-kkc,
I changed your units using -dwgunits to Inches instead of feet. Then, I ran surfsculpt to get everything into a single solid. I was able to export the STL and open in Inventor and it measured correctly. I also brought it into Fusion 360 to verify that it looked good.
 I next took the model into PrintStudio and added supports and everything looks good.
So, I suspect that you need to revisit your print process as this seems to work great on my side.
John Vellek
Message 7 of 10
Alfred.NESWADBA
Look to >>>this description<<< (or others), a STL-file does not contain any information about units.
The only thing you can do with -DWGUNITS is to scale the objects, then the result is that the objects are larger or smaller (but only the values you get by "_DIST", independent of units). That gives also another result in any STL-viewer looks larger or smaller. But again: indenpendent of units-setting in AutoCAD.
You can set the AutoCAD units to Angstroms or Lightyears, it does not change anything for the exported STL 😉
- alfred -
Alfred NESWADBA
Message 8 of 10
kcol-kkc
Alfred hit it square on the head.  The units in the STL file are just numbers.  My Slic3r was reading the units a mm.  But my AutoCAD was drafting them as inches.  I... assumed if drawn in inches they'd come into Slic3r as inches.  Wrong assumption.  I have not had any success switching Slic3r over to imperial units so instead I have scaled my drawing up 25.4 and the .stl file comes into Slic3r at the correct size.
I hope I explained that correctly.   The issue is not AutoCAD it's my slicer software.
Message 9 of 10
kcol-kkc
John,
The supports you drew are impressive.  That is the next hurdle for me to get over is supports and understanding when and how to use them.  Is this PrintStudio an Autodesk product?
Message 10 of 10
john.vellek
Hi @kcol-kkc,
I set the units in my file as decribed earlier from feet to inches because I tried a variety of exports and didn't want to play with scaling. I know that the IGES file I created and brought into Fusion 360 worked very well. I then "Printed" to PrintStudio which is an Autodesk product. It allowed me to auto-scale, auto-orient, check for errors and then easily add the supports.
John Vellek
