PDF Transparency in Drawing
AllenJessup
Mentor Mentor
Message 1 of 10
AllenJessup
I have a PDF Underlay with an image in it. Is there any way to make it transparent? I need to align it with another image but I need to be able to see the underlying image.
Allen
Allen Jessup
CAD Manager - Designer
Replies (9)
Message 2 of 10
h_s_walker
Doesn't FADE work from the properties menu?
Howard Walker
Left Handed and Proud
Message 3 of 10
AllenJessup
FADE Fades the PDF but you can't see anything below it. As a workaround I'm tracing a building in each image and using that as a reference.
Allen
Allen Jessup
Message 4 of 10
h_s_walker
Is sending the PDF to the back not an option?
Howard Walker
Message 5 of 10
AllenJessup
No. Because then I can't see through the image to the PDF.
Allen
Allen Jessup
Message 6 of 10
m_kingdon
PDFs are documents not images and are not treated like images. When you insert an image (jpg etc) a "Background Transparency" option is available that allows objects behind the image to be visible. If you can, convert the PDF to a jpg or similar
Mike Kingdon
Civil 3D Zealot
Message 7 of 10
BrianBenton
Have you tried turning on transparency and setting the transparency of the PDF to 50%?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 8 of 10
AllenJessup
I don't remember. I'll see if I can try that later. Past that point right now. I'm only doing 3 things right now but it feels like 5.
Allen
Allen Jessup
Message 9 of 10
How about converting it into an editable DWG file? Try this converter, I thinks it may help.
http://www.autodwg.com/download/PDF2DWG-SA2015.exe
Message 10 of 10
willXXXDP
PDFs now have transparency in the properties tab. You can adjust there.
