Polar Array
Polar Array
Polar Array
Hi, I am trying to figure out if there is an option in the polar array that will not round up when I enter a degree. I am polar arraying a set of items and the distance between them is 32.73. When I enter this in the "between" under items, it automatically rounds it to 33 degrees. Is there any option to make it not do this?
Thank you in advance!
Kent1Cooper
That is probably only a matter of display resolution -- I think you will find that it uses the angle you specify, even if it shows it rounded.  Get into UNITS and set a higher degree of precision for angles.
Kent Cooper, AIA
Your solution worked!Thank you!
