I have a PDF Underlay with an image in it. Is there any way to make it transparent? I need to align it with another image but I need to be able to see the underlying image.
Allen
Allen Jessup
CAD Manager - Designer
Solved by m_kingdon. Go to Solution.
Doesn't FADE work from the properties menu?
Howard Walker
FADE Fades the PDF but you can't see anything below it. As a workaround I'm tracing a building in each image and using that as a reference.
Allen
Allen Jessup
Is sending the PDF to the back not an option?
Howard Walker
No. Because then I can't see through the image to the PDF.
Allen
Allen Jessup
Mike Kingdon
Civil 3D Zealot
Have you tried turning on transparency and setting the transparency of the PDF to 50%?
I don't remember. I'll see if I can try that later. Past that point right now. I'm only doing 3 things right now but it feels like 5.
Allen
Allen Jessup
How about converting it into an editable DWG file? Try this converter, I thinks it may help.
