Are you trying to convert a PDF to editable objects in Autocad?
If so, Autocad 2018 has the ability to import editable data from a PDF depending on how the PDF has been created.
This does not work on scanned PDF's.
There are some 3rd party programs that allow to to convert PDF's to autocad objects but mostly they do not produce satisfactory results.
Hi @Anonymous,
For 2015 you will need a third-party product most likely. One I used to use with good success was called Able2Extract. I believe they still offer a trial version so you can see if it works well for your workflow.
I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.
Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
Hi @Anonymous,
Did you try the application I suggested? I would like to know if it performed well for your process.
