PDF to DWG converter best for AutoCAD LT 2015
No aplicable
Is there a better PDF converter that works for AutoCAD LT 2015?
0 Me gusta
Responder
5.422 Vistas
6 Respuestas
Respuestas (6)
leothebuilder
Are you trying to convert a PDF to editable objects in Autocad?
If so, Autocad 2018 has the ability to import editable data from a PDF depending on how the PDF has been created.
This does not work on scanned PDF's.
There are some 3rd party programs that allow to to convert PDF's to autocad objects but mostly they do not produce satisfactory results.
0 Me gusta
john.vellek
Hi @Anonymous,
For 2015 you will need a third-party product most likely.  One I used to use with good success was called Able2Extract. I believe they still offer a trial version so you can see if it works well for your workflow.
I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.
Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
John Vellek
No aplicable
Thank you very much for the feedback
0 Me gusta
No aplicable
Thanks for your input.
0 Me gusta
john.vellek
Hi @Anonymous,
Did you try the application I suggested? I would like to know if it performed well for your process.
John Vellek
0 Me gusta
No aplicable
No I have not yet. Been doing other projects right now. Will let you know when I do.
