AutoCAD Forum
PDF Publishing problem
11 REPLIES 11
Message 1 of 12
672 Views, 11 Replies
HI everyone.
I'm having a problem when publishing my Layouts to PDF. Keeps publish extra elements that are on frozen layers ( as you can see in the pic) It doesn't matter if I'm using the sheet set manager or the publish command the extra elements are always there.
Does this happen to someone else?
11 REPLIES 11
Message 2 of 12
imadHabash
Hi and welcome to AutoDesk Forum,
could you please attache the CAD file here for testing and give you proper answer?
Waiting..
Imad Habash
Message 3 of 12
Thanks for the quick reply. The problem is not with one file but with all of them.
Message 4 of 12
imadHabash
Ok..Let's try to Disable Hardware Acceleration from 3DCONFIG command.then try to publish and see the result.if the problem still existing just attache a small CAD sample that we can test it.
Good Luck..
Imad Habash
Message 5 of 12
in reply to: imadHabash
It solved it, but with Hardware Acceleration turned of AutoCAD performs much worst. Is there any solution around this?
Thanks a lot for your help.
Message 6 of 12
Alfred.NESWADBA
when you use _PLOT instead of _PUBLISH using "DWG to PDF.pc3" ... do you get the same issue?
As we can't see the AutoCAD version you are using: which version do you have installed and do you have installed all service packs for that version of AutoCAD?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 7 of 12
imadHabash
try to turn it ON again and see if the problem disappear.if not you can turn it on and try to untick one of those boxs below (in hardware dialog).
Imad Habash
Message 8 of 12
When i untick high-quality geometry everything is fine. Thank a lot for your help.
Message 9 of 12
in reply to: Alfred.NESWADBA
I did get the same issue with plot or publish. I'm using AUTOCAD 2017.
Message 10 of 12
Alfred.NESWADBA
Strange, that's the first time I see that options set for the graphic card influence the output when plotting to PDF.
Are you sure that you have installed all service packs/update for your AutoCAD?
- alfred -
Alfred NESWADBA
Message 11 of 12
Hi Alfred.
I just installed the service pack for autocad17 and now it is plotting perfectly even with the Hardware acceleration on.
Thanks to you both for your help.
Message 12 of 12
Alfred.NESWADBA
Great that it works now as designed, thx for the feedback!
- alfred -
Alfred NESWADBA
Forma Design Contest
