Using Cute PDF. PostSript custom pages size 24x 38. Preview is ok but print is offset and cropped. If anyone has ideas I would be grateful. It has printed fine previously and no changes were made as far as I'm aware.
Autodesk KM Publish to PDF yields offset results in AutoCAD
Your first image is a screenshot of the Page Setup for the layout tab named A360. Go back to the Page Setup and make your selections as shown below then click PREVIEW. Take a screenshot of this Preview using the new settings. Upload this screenshot. Close the preview and click OK to exit. Next, start the PLOT command.
While in the PLOT command, keep all settings then click PREVIEW. Take a screenshot of this preview and upload it. This screenshot should be in addition to the PREVIEW of the screenshot taken from the Page Setup. Comparing the Plot Preview against the Page Setup Preview will likely show the parameters that must be corrected.
Issues you are currently facing:
Thank you for your comments. I have done as you suggested but unfortunately it didn't fix the problem. The print preview and final result are different. The print purview appears okay but in the final print the drawing is shifted to one side and cropped. This issue has only emerged since I upgrade from AutoCad 2020 to 2021 and never experienced the problem with previous versions over the past 25 years.
Thank you for your reply, Autocad's default printer works with the custom size! Success!
The problem is with CutePDF.
Thanks to all for their comments!
