Hello
I can not figure it out on my own. No matter what I do, it doesn't work.
Anybody, PLEASE HELP!!!!!!!
When I create a PDF file out of paper space and print it, scale is not 1'=20'. It's slightly smaller.....
Solved by ChicagoLooper. Go to Solution.
Make sure "Fit to paper" is not checked when creating the PDF from AutoCAD in the PLOT settings, and also make sure that the PDF is being printed from your PDF program without scaling. It'll probably say something like "Fit", or "Scale to fit", or "Fit to printer margins". You want to print to "Actual size", or "No scaling", or similar from your PDF program.
just want to add to the valid suggestions from @nrz13 ...
Please first verify if the PDF is incorrect or later then the plot.
Then you know if you need to correct the plot settings inside AutoCAD or you need to correct the settings of your PDF-viewer when printing the file.
- alfred -
You are trying to plot paperspace and that's good. Your titleblock is in modelspace and that's bad. You can do this to MOVE your titleblock to paperspace, where it belongs and should be, and correctly plot to an 11x17 sheet at 1"= 20'.
NOTE:
Your current sheet size on your layout tab is not 11'x17." It's actually 339" tall and 220" wide. Your plot configuration is not your issue, it's your sheet size, it's too big!
CREATE A NEW LAYOUT TAB
PLOT SETTINGS FOR 11X17 PORTRAIT & REMOVE 'NON-PRINTABLE' AREAS RUNNING ALONG THE SHEET'S BORDER
Note: If you also want plot to 11x17 landscape, you'll need to do two things: (a) change the paper size from ANSI full bleed B 11.00x17.00 Inches to ANSI full bleed B 17.00x11.00 Inches and (b) modify the printable area for this new sheet. It's considered a 'new sheet' because it has a slightly different description. You may save these additional settings to the same pc3 file you saved for the portrait orientated sheet, the one with _rev2 added to the end, because both 'sheet descriptions' can live side-by-side in the same pc3 file. Whenever you plot to 11x17 or 17x11 AutoCAD will remember all the pc3 settings for you.
MOVE YOUR TITLEBLOCK FROM MODELSPACE TO PAPERSPACE
You'll immediately notice your titleblock is too big. You'll need to resize it so it will fit on your 17" high X 11" wide sheet. Use the SCALE command to resize you titleblock using the outer rectangle as your guide by making the vertical edge of the outer rectangle exactly 17 inches tall, no more and no less. All objects 'inside the outer rectangle will scale accordingly.
FINAL LAYOUT
ADITIONAL NOTES:
When you're done plotting, you may save this drawing with .dwt extension, the proper extension for an AutoCAD template. Before saving the template to dwt, delete all objects in modelspace so it's completely blank. Save only the 11x17(NEW) layout tab objects. Becuase you have moved your titleblock from model to paperspace, you can now reuse this titleblock for future drawings. You'll still need to revise and update all the text notes but your plot setup will remain intact because your plot settings, e.g. plotter driver, sheet size and sheet orientation, live inside titleblock dwt file.
